On an un-crowded ramp, back you boat about 3/4 the way into the water, leave it strapped on the trailer, set your e-brake, put your vehicle in Park, and climb onto the back deck of your boat. Pop the rear hatches and with the help of a flashlight and your free hands, look and feel around all of the hose fittings, bilge/aerator pumps for any signs of water intrusion. Over the years, I have discovered numerous culprit leakages from several not-so-obvious sources (hairline cracks in bilge pump nipples, bad Mayfair pump cartridge gaskets, slightly loose hose clamps, etc, etc) Youre also gonna get some water in the bilge from your ice chest, if you used it that day, and yes, a little water will dribble into your bilge area from the resulting backwash after a hard stop on the water.
