The Silicone is not loose on the boat usually. There may be a very thin line that does not adhere to the rub rail, and it can peel off. You can rub it off also and trim it with a razor blade. It usually last a while before it starts to peel, and it should only be about an 1/8″ width, and a film thickness, or less line of silicone where they taped the rub rail, then caulked the joint. If it is not there, then the warranty would have a part in this. It is a seam cover more than anything else. BCBLast edited by Bass Cat Boats on July 18th, 2008, 6:10 am, edited 1 time in total.
