now I need to work on the rear one, but its a different problem. What Im seeing when I look down from above it is about a 1 mm gap all the way around the bushing and the post support below can be made to move from side-to-side. This seems to suggest to me that replacing the bushing might not cure the seat wobble. Do you think a new bushing would help at all? What about a shim or would some type of filler/cement work better? Its a 02 P3 and the bushing in the rear is the white one.I was a little surprised to find that in contrast, the front bushing was the smaller diameter black one. BTW, your tips for removal of the old one were very helpful, but I too found the new one to be much too tight after installation (even after cleaning all of the pitting from the seat post with emery cloth). I had to use a rat tail file to hone it out. sorry for the long-winded post and lame questions…thanx!
