On mine, you can remove the sending unit and have a pretty good hole to see through. Id look for kinked/pinched hoses first. Done anything new in the bilge area such as replacing a battery, or moving something around. Easy enough to pinch the fuel line. If that is not it, you can probably remove the pickup line at the top of the tank. If the bulb now acts normally, the problem is inside the tank, if the bulb wont spring back to its full shape with the pickup line removed, you have to look north of that point to find the restriction.It is obviously restricted somewhere. Really should not be that hard to find…
