Most would be able to handle the install. We actually do not suggest the Exact Dial as you have to only use the Exact Dial switch for it to work properly. If you are accustomed to that, then it will work fine. Once you use the trim stalk switches on the column, the settings are all wrong. It must start at the bottom and then it will be fine as long as you only use the Exact Dial. BCB
