2003 PII batt. drain
Hey guys my buddies PII has been draining start battery. Battery has been replaced and load tested system is three bank onboard charger for 36 volt troll and seperate charger for cranking batt.. He has 200 opti with a group 27 800 cca batt. problems started with graph turning off and then worked there way to killing the battery mid dayweve been replacing batteries and chasing the problem for a while.The boats electrical is a fair mess with smartcraft tapped into existing harness so now if you charge the batt. and let it sit for a hadful of days the starting batt. will drain. We removed the stereo and any unnessasery wiring we could find , we had a starting buddy added ( one of those deals that pulls power from the trolling motor when the starting batt. dies). Now mid day he is loosing start power and having dead trolling motor issues.I pretty sure there is a sugnificant drain on the starting side any suggestions where i should start to look and how ??
Home Forums Bass Cat Boats 2003 PII batt. drain
Viewing 9 posts - 1 through 9 (of 9 total)
