Water in Fuel Tank???
Gassed my boat today at Costco (first time there, almost always use 76 in the boat although normally gas truck there all the time). Put gas in both tanks with 7 gal. in left side and 9 gal. in right side bringing both to close to full. About half way thru the days fishing the smart craft gauge warning buzzer went off and showed "water in fuel tank". Each time I started after that it happened. In Calif. Delta a long ways from ramp at the time. Did not think to switch from the right to the left tank to see if it showed there too. Now..I did run pretty slow back to the ramp with no problem except warning buzzer kept going off. Since I have never had this problem before concerned that could cause problem in motor???? Maybe someone here can help and tell me what I need to do to clear this up. Is it necessary to drain the gas tank? or tanks? That would be close to 32 gal. of gas..................Any help??? Thanks
Home Forums Bass Cat Boats Water in Fuel Tank???
