Different styles of Oils clabber if they stand, and they turn to a stringy wet cheese looking mess. Those can clog the screens and damage oil pump operation.
Mixing them is fine if you use your boat regularly. It is not a good idea if you use your boat less than a few hours a month. You have to use the boat enough to run the existing oil through the system. Those that sit are the one that give issues.
