SOLD | FL | 2021 Bass Cat Margay
SOLD | Become part of the Bass Cat family now with the new 2021 Margay for a UNBEATABLE price! The Margay is the definitive “bang for your buck” choice!! Handles like a Go Cart, can get in almost anywhere!  No competitor can even come close to what you get in this Bass Cat, and LOOK at what you get with it.. Explosive power with a Mercury 150HP Pro XS, Minn Kota ULTREX 80/MDI/IP 45”, Humminbird Helix 9 CHIRP on the console, Humminbird Helix 7 CHIRP at the bow, Rear SI Transducer Shield, Butt Seat w/ Pro Pole and more!!!!  This boat will not last, text or call Josh ASAP -  (321) 503-4001. Video: https://youtu.be/9Kgep3OtvO8
Specs: Length - 17'7 W/Swing Away Tongue - 20'4" Beam - 90" Approx Boat Weight - 1250lbs Fuel Capacity - 26 gallons Max H.P. Range - 70-150 Upgrade Features: Minn Kota Ultrex 80/MDI/IP 45” Humminbird Helix 9 CHIRP MDI GPS G3N Humminbird Helix 7 CHIRP MDI GPS G3N Rear SI Transducer Shield Water Pressure Gauge 1/2” Trim Stripe Hull w/ Black Pins Butt Seat w/ Pro Pole Reverse Console and Fender Color - Malibu Silver Teleflex Tilt Helm Additional Rod Bungee Custom Trailer: Single Axle 3" C Channel frame - US Steel Fiberglass Trailer Step Three (3) cross members - US Steel Pivot Tongue (3" Fr. Trailer Only) IMCO Tie Downs No Brakes 14" Aluminized Galvanized Wheels w/Spare PPG Clear Coat (1) Vault Hubs Black Frame STD Tandem Requires 4in Frame & 4in Frame req. Brakes Standard Features: Perko Latches Integrated SS Ladder in Deck Windscreen 750 GPH Bilge Pump w/Auto Aeration & Pump Out Feature - Pull Aerator Head Oper. 26 Gallons of Fuel Two Fold Down Seats Quicksilver Matched Analog Gauge Package Center Rod Storage w/Tackle access below One Rod Bungee at Bow Ice Chest Cooler 24oz Carpet Black Pinstripe 3 blade propeller - Fury is an upgrade Sea Star Steering - no tilt 8in Jack Plate (Slidemaster) 6X Steering Wheel Interactive Digital Panel Master Power Switch at Dash Automatic Bilge Matching Gauge Dress Rings color coded Aluminum. Trim Gauge Four Cleats Foam Filled Stringer System
Home Forums Bass Cats For Sale SOLD | FL | 2021 Bass Cat Margay
Viewing 15 posts - 1 through 15 (of 15 total)
