Sorry you are having issues on the Pro XS and we appreciate the understanding that our products are separate of Mercury.
First the actuator is the one item there have been some multiple issues with. The gearcase is not a common issue unless it is related to bearing wear and that is a limited issue we have known of, and your dealership is the one dealership we know of which has seen that before. These are all issues only with the lower unit and shifting areas. The engine, ignition, trim and powerhead haven’t presented you an issue apparently.
The positive things is this is all lower midsection and down issues, which are an easy bolt on and bolt off part. That would be our suggestion and we will get with Bait Shack and make another suggestion.
BCB
