IL 2012 Puma FTD For Sale
2012 Puma FTD Original owner. Boat has been garage kept and well maintained. Outstanding condition. ·        BCB trailer with swing away tongue ·        Dual console ·        2012 Mercury 250 ProXS (245 hours as of 2/1/2023) Mercury Quickleen and Quickcare added to all gas put in the boat. ·        Fury 4 blade prop 26P ·        Slidemaster Jackplate w/ safety ladder ·        BCB NexSys Link Gauges w/ LCD (including manual) ·        Speedometer, water pressure, trim, fuel, and tachometer gauges (analog) ·        2 Pro-Pole Butt Seats ·        Dean’s Aurora Custom Cover w/ Motor Cover (black) ·        Motor Guide TR82FB-45 (24v) (82 pounds of thrust) ·        2 Deep Cycle AGM batteries ·        AGM cranking battery ·        Troll Tamer for MotorGuide ·        Lowrance HDS 7 at bow ·        Lowrance HDS 10 flush mounted in console ·        Ethernet connection between Lowrance units ·        Pro-Trim single stack ·        Noco 3 bank battery charger ·        Hamby keel protector ·        2 retractable rod straps on front deck ·        Center seat in cockpit ·        Grab post and steps on trailer ·        Reverse light on trailer ·        Hot foot with slider bracket ·        Boat buckle retractable tie downs ·        Spare tire with BCB cover ·        Fulton XLT jack on trailer ·        Single aluminum battery tray ·        Dual aluminum battery tray $40,000.00 Contact Kevin via email, text or call 630-890-2129. I am located in the suburbs of Chicago. More pictures available upon request.
Home Forums Bass Cats For Sale IL 2012 Puma FTD For Sale
