Bilge Pump Issue
I have 94 PII,  Have 2 bilge pumps with float switch, both Pumps work fine when switch is in auto and float is activated. When I put the switch to manual. I get nothing.  It worked fine last season. This is non A10 or BP boat it is a manual rocker switch.  When i checked voltages I have only 1 RED hot wire.  there are 5 wires coming to the switch.  the switch is a 6 pin switch, I assume in manual the voltage comes in and out through the 2 brown wires that are on the same side of the switch. Red (HOT), Double black (Grounds) 1 Brown/ White 2 Brown wires       thank you in advance for any help
Home Forums Bass Cat Boats Bilge Pump Issue
