Water pressure gauge reading zero.
Was running the boat. Looked over at my water pressure gauge, and it was at zero. looked back at the engine and it was peeing/spraying as it should be at speed. No alarms. So I continued to the ramp and loaded the boat. What is the best way to troubleshoot this issue? No leaks at the gauge. Nut is tight. Thanks Don
Home Forums Bass Cat Boats Water pressure gauge reading zero.
