Sabre Performance – Still Chasing
Bass Cat Crew - I’m sort of at my wits end and need some guidance on my  2017 Sabre w/Etec G2 150. Started off running a 24 pitch Raker HO at 3.5” ptp , saw 60 mph, boat felt like there was more speed to be had. But the engine felt to low. Went to 3” ptp  and a 25 pitch Raker HO saw 62.5 mph but ran into limiter issues, not low water pressure. Speed would have increased if I could have trimmed up more. I was about 60% on my digital trim gauge before had to stop due to high rpms. Went to 3.25” ptp with 25 pitch Raker HO and had to trim to almost 70% to get 60mph. Had a rooster over cowling high to get any speed. Boat felt “heavy” and not nimble at all. I’m not only worried about speed. Just want best  performance, adequate water pressure, and under the limiter. Do I go to 2.75” and try to run flatter with less trim? Do I go back to 24 pitch prop and 3.5”  knowing there’s more performance there but it’s not attainable? I just want to put the experimentation to an end. Appreciate the help….
Home Forums Bass Cat Boats Sabre Performance – Still Chasing
