The passenger seat on my 06 puma is loose and I cant see how to tighten it. Are there screws under the foam, and if so, how do I access them? Thank you for the help.
You probably will have to remove the lower cushion by the front screws and then check the lower panel mounting into the seat box that the seats mount in.There are inserts that have given us some trouble from incorrect tensioning when crimped into the box. BCB
