No Pantera II models in 2002 either. None since the late 90s till recent models.Madgaffer, try looking at each individual wire on the battery for a drain. Then record what those levels are. Once you have that data add it all up. Though we are suspect of the battery, and we do not like any of the dispersion systems that use trolling batterys for back up. You can just use a short set of jumper cables to pump it up if you need it. This is like trying to cover up a potential problem. A very high percentage of batteries are sub standard also. So just because it is new, does not indicate it is quality and if it is a (N)Everstart, then all bets are off. We have preached quality cranking batteries for a long time now, and we keep preaching it. BCBLast edited by Bass Cat Boats on May 31st, 2010, 5:13 pm, edited 1 time in total.
