2006 PIV Trim/Smartcraft issue
Trim gauges(2) - Smartcraft and standard dial type (installed in console) will not read below "Trailer". Boat tech did a check and says its a gauge issue not sending unit or bad ground, he hooked up another gauge and it reads normal while traveling up & down. How can both gauges be faulty the same way? Is there a single wire delivery system for this type of set up? Sent an e-mail to BassCat parts last weekend but no answer from them yet. How hard is a switch out and how much (if available) $$$ for replacement of both or either? Is there a way to check a common wire to both? Also have numerous lights out on the A-10 touch pad (all switches work though) and thinking of replacing it also if I can get a price and answer on difficulty of replacement.Thanks for the help.Tom
Home Forums Bass Cat Boats 2006 PIV Trim/Smartcraft issue
