2006 Puma Ram Mount At Bow Access
Have a similar question to gmcfarland but did now want to highjack his post as his question was regarding the Cougar, I have a 2006 puma. Have a screw hole that stripped when mounting the ram ball. Cannot reach it through the rod box or other access points. It is acceptable to do as Phil said drill a 3 inch access hole under the trolling motor foot pedal to get access to use bolts and self locking nuts then use the plastic cover plate, like the one used on the passenger side for access to the passenger console hardware to cover. Any water issues in either of my rod boxes if I make a hole under the trolling motor foot pedal, should I seal it with marine silicone to prevent water leaking in? Currently has the Minkota Maxim trolling motor. Thank you for your help.Jack
Home Forums Bass Cat Boats 2006 Puma Ram Mount At Bow Access
