2008 Pantera Classic Transducer help
Considering replacing original lowrance units either Lowrance HDS Gen 3 and or Elite Ti 7 inch units for both the console and bow. First do I need two separate transducers or can they share one? Secondly where is the optimal position on the transom (any pics would help) or is it better thru the hull (if thats even possible with the standard transducer from the box). Are there any limitations if I were to do a HDS at the console and a Ti at the bow as opposed to two of the same units. Finally hoping to leverage my existing power lines from the LMS 520C (console) and the HDS 5 (bow unit) so as not to have to snake one set of wires., is this possible? Tks
Home Forums Bass Cat Boats 2008 Pantera Classic Transducer help
