2008 Puma question after impact
I have '08 puma with a 250 merc proxs running a 25 fury 3.  Yesterday while running the local pond i found out the hard way that some ass clown removed some markers. I tattooed what i thought to be a stump. The alarm beeped once so i shut down.  When i raised the motor there appeared to be zero damage.  We idled to where we were going, temps fine, zero vibration.  After fishing and heading back i noticed that the nose does not want to lift and when it does finally, the boat will fall off pad very easy dropping the nose back down.  When i got the boat on the trailer I crawled under and inspected the hull to find zero scratches or impact areas. To the naked eye the prop appears to be fine, manual jack plate still in the same position.  Does anyone have any ideas on what to check or look into?
Home Forums Bass Cat Boats 2008 Puma question after impact
