2013 P4 Tilt helm pump leaking? 6 inch stain on carpet under console
2013 P4 6 months old. I got home and when putting the boat in garage i saw oil all over the driver seat. I then noticed a 6-8 inch diameter stain on the carpet under the console. When i looked under the console I saw oil all over the helm pump and hoses. Not sure where the leak is because it blew oil everywhere it appears. What would cause this? How do I fix it? and how in the world do you get the stain out of the new carpet? I pulled the boat to get powerpoles installed and had not turned the steering wheel or driven the boat only pulled it there and back. I always use a regular transom toter if that makes a difference. Dealer is a 3-4 hours away. I have read about the shaft seal going bad but would this cause such a large leak in the rear of the helm pump?
Home Forums Bass Cat Boats 2013 P4 Tilt helm pump leaking? 6 inch stain on carpet under console
