2013 Puma FTD Bow Eye Replacement
The bow eye on my 2013 Puma FTD broke.  I've ordered the replacement part from BCB but wanted to check to see if there are any tricks/tips for access. Is there an access hole under the trolling motor pedal or will I need to go in through the panel with the trolling motor plug? Thank you. Patrick
Home Forums Bass Cat Boats 2013 Puma FTD Bow Eye Replacement
