VT 2008 Bass Cat Puma – 2005 Merc Optimax
BassCat Boat for Sale
2008 BassCat Puma wide body, 20’4’, SC, EXCELLENT CONDITION,
*tilt steering wheel * dual pro trim *hotfoot with slide plate *4 bank on-board charger
*2 bike seats * 1 sit down seat *Hamby’s Keel Guard * Security Theft Alarm
* Lighted/ lockable compartments *Recessed trolling motor for pedal *52 gal gas tanks
* Smartcraft Guages * Water Pressure guage * New Atlas Jackplate Guage *Trim guage
* New livewell pump * New Livewell switch by console *Aerator & Recirc Pumps
* Pump in & pump out pumps* Bilge Pumps
* Dash- Lowrance LCX-27C, LCF 1440 Flasher, Front- HDS-7 Gen1, LCF 1440 Flasher
* BassCat /Deans Trailerable Boat Cover * BassCat/Deans Separate Motor Cover
* (2) Motorguide 109 lb 36 volt Tour Edition Trolling Motors, one with Ninja Grass Blade
* Transferable Lifetime Warranty on boat hull * New Atlas Hydraulic Jackplate
* Hydraulic steering, recently recharged last fall *New Hydraulic Cylinder Seals
2008 BassCat Puma Custom Tandem Trailer, * Tandem Brakes, *Gator Hyde finish
* Custom ordered stainless steel brake lines * Step pole and step-up front plate
* 5 New tires * New Backup LED light * New bunks just replaced * Claw Wheels
* Swing/hinged trailer tongue * LED Trailer Lights * Quick Ratchet transom straps
2005 Mercury Optimax 225HP Motor *New water pump *New spark plugs
- 400 +/- hours (have printout from service computer of RPM history of break-in & breakdown of motor hours with arroximately 15 hours at full throttle) Most hours between 3,000 and 4,000 RPM’S!
- Regularly maintained, never any problems
- Always stored in heated garage in winter and garage kept in summer
- Tempest Plus 3 blade 25 pitch stainless steel prop, blueprinted
- Backup Trophy Plus 4 blade stainless steel prop
- Spring loaded motor totor/transom saver
- Always used Mercury Brand DFI oil and Quickleen Engine system fuel cleaner
- Always run high octane, non-ethanol gas
Also have to include: *9 Gallons of DFI Mercury Oil ($270.00 Value)* 15 bottles of Quickleen
Asking $30,000 (New Replacement $70,000 plus!) * Have clear titles in hand
