Probably been covered before but, any suggestions on a couple of durable, long lasting and affordable trolling batteries? Also , they must fit in the aluminum battery trays.Any suggestions would be appreciated. Thanks!
From my experience my minimum choice for troopers is a series 29. Ive had too many issues with 27s personally fishing tournaments. If you arent fishing derbys then 27s are o.k..
When I change I will go with the battery with the most RC. As you can see in the chart not all 31s are the same.http://www.trojanbattery.com/pdf/Traile … 201105.pdf
SPHidalgo wrote:When I change I will go with the battery with the most RC. As you can see in the chart not all 31s are the same.http://www.trojanbattery.com/pdf/Traile … 201105.pdfNICE READ THANKS,,,ROBIN
