3 Way Cutoff/Jump Start Swithc Installation Completed.
Finished the installation of a 3 way BEP 701S switch (finally) in my 2007 Sabre FTD. Same switch used on the Ranger 3 way switch.Ordered a 4” piece of Starboard, pre-drilled for the mounting screws, and switch, and mounted it to the rear seat post. Bought 4 gauge tinned cable with HD double wall tinned terminals pre-made from GenuineDealz.com. Perfectly crimped and sealed with adhesive shrink wrap. Highly recommended for pre-made cables and supplies.And you can customize the terminals for different size posts as I needed 5/16” at switch and 3/8” at the batteries.I used laminated plastic tags to label the positions of the switch since it had to installed with the start battery wired to #2, and the TMs wired to #1 as dictated by the battery positioning in the bilge. Still might reposition or route the wiring differently, but it’s operational, and does what it’s designed to do. I love a project. Sorry for the closeup pictures. Tight quarters in the bilge.Thank you to John Jones at Jone’s Trolling Motor for clarifying the connections on the TM batteries. Thank you John.
Home Forums Bass Cat Boats 3 Way Cutoff/Jump Start Swithc Installation Completed.
