JMy fuel tank on left side shows full all the time on the super dash, I took the sending unit out and it works manually and the gage on top of tank is accurate but the electric part doesnt register right , I ran a jumper wire across to the right side tank and it registers the right amount of fuel on the dash so I know its not the wiring or the dash but I didnt know if I could get a new sending unit that would work with the digital dash as old as the boat is just thought I would check here first to see if any of you guys could help thanks in advance!
Those are upper grade Rochester sending units and Mirax had that same fuel sending unit. We don’t have that actual part in stock and usually it’s just the top CAPSULE that fails. You can buy just the capsule also and we do suggest that.
