A-10 question
Im in the process of hooking up a LSS-1 / Lowrance side scan. Im going to mount it in the back of the starboard rod loocker. I want to hook the power up to the ACC on my A-10. I read on another post that the pink wire is the ACC on the A-10. the pink wire on mine is running into the hole on the starboard side along with the rest of the wires and is taped and tie wraped to the other wires. is it just laying in there? I already mounted the transducer to the jackplate and removed the starboard vent. Im going to use the GPS puck wire to pull 2 strings to the console and use one to pull the transducer cable to the console and the other to pull the ducer wire back to the puck. It is just a short pull from the starboard hole under the console to the rod locker. any advise on this before I get serious about mounting it? Last edited by txmrbass on April 21st, 2010, 1:25 pm, edited 1 time in total.
Home Forums Bass Cat Boats A-10 question
