ACC#2 on control panel 2022 EYRA
Hello, Im new to the bass cat forum and was hoping someone can help me out.  I own a 2022 Eyra equipped with 2 power poles.  The power poles can be shut off using the main power switch that was installed in the rear battery compartment.  When the boat is parked I need to go into the rear compartment to shut the power off to the power poles to prevent drain on the cranking battery.  I would like to use the ACC #2 button on the control panel (orange wire) to turn the power poles on and off when need be.  From what I was told the ACC#2 button is only for low amperage and was wandering if I could install a relay to handle the load amps ( up to 80 amps with 2 power poles)  from the power poles.  This way the ACC#2 button will only power the coil within the relay in which closes the switch within the relay.  It would be more convenient without having to go into the compartment to get to the power pole switch when I can just turn them on with the ACC#2 button on the control panel.  Any ideas or help would be much appreciated.   Sorry for my terrible literature in advance.  LOL . Thanks Shawn
Home Forums Quest ACC#2 on control panel 2022 EYRA
