The lights in the livewells are simple, and you can use the Accessory switch on the dash to activate those. The lights in the boxes are more intense, and they wil require a loop wiring harness added into the boat, with pod switches that screw on the lids, and light strings in the boxes. It would be easier to add an aftermarket light capsule to the boxes. Though not the same set up as BCB.BCB
