I use contact cement, depending on how much is seperating I lift corner and apply to both the back of anti slip material and fender. if a large portion has seperated you may be better off fully removing and giving the fender a light sanding to remove the old adhesive then follow same procedure to reattachTreat everyday like it might be the last
