Battery Draining
I had my local Merc dealer take a look at my boat. Was having the oil horn/light come one and will not go off. Found the sensor to the upper tank under the cowling was bad. Also had suspected that something was draining my cranking battery. They did a check and found the horn switch on my A-10 touch pad was shorted "closed". Do I need to replace the entire touch pad or is there another fix?
Home Forums Bass Cat Faq Archive Battery Draining
