Bilge pump power
Second hand, 1996 pantera. The bildge pumps were hooked directly to the battery with a three way switch under the rear hatch. I checked power from the panel and I have power to the main harness when on manual. So I connected a new 500gph to the harness. but nothing happened. I then checked another pump and still no power. Disconnect and checked harness agian and shows power on volt meter. Whenever I put a pump on the harness the power shorts out or something else is going on because there is no power on the volt meter. I read on another thread that the panel may have a sensor that is shutting down the power to the bilge pump. All other panel features are working. What are your thoughts. If it is the panel can I fix it. Thanks Aaron
Home Forums Bass Cat Faq Archive Bilge pump power
