Bilge pump wiring??
I checked my Livewell system the night before a tournament this week during prefishing and in my checks I noticed my livewell fill (Freshwater) pump was not coming on...I got the problem narrowed down to a green ground wire running from the pump to the switch...I ran a jumper basically from the Switch across the deck and into the well to the pump and it worked...It was getting dark so I ran it like that for the tournament...When I got home I checked the original green wire with an ohm meter and it shows OL.....My questions are....Is this wire ran directly to the switch or is there a terminal someplace?? If it is ran directly to the Freshwater livewell switch can I use the old wire to pull the new wire through or is the harness taped or Zip tyed off under the cap??? What guage wire is that Pump wire?? It looks like 16 guage...Thanks for any help....I felt stupid having to run the wire across the back deck but when your running out of daylight and your tackle all needs to be retied and organized you have to get ready to compete at some point...It just seems strange to have a wire just fail like that...I thought it may be the connections but I cut them off and checked with bare wires.....It is on a lightly used 97 jag.....The big water may beginning to take its toll...Thanks again,Brian...
Home Forums Bass Cat Boats Bilge pump wiring??
