Bilge pump wiring or a10 panel?
I have an 03 ftd that Ive had for a while with no real electrical issues and bilge pumps are not working in manual or auto. All other pumps/switches work. I thought it was cartridges but after a swap, no change. Original cartridges also work perfectly when connected direct to the battery. When I press the bilge button on the a10 panel, the light turns on and I can hear the relay click but nothing happens. I did have a broken wire on the auto float early this year, but everything worked fine for months after replacing the float. Im looking for suggestions on where the issue could be and possibly a wiring diagram so I can start probing the a10 connector to nail down the issue. Thanks in advance!
Home Forums Bass Cat Boats Bilge pump wiring or a10 panel?
