Bow panel Motor tilt not working
21 Eyra I've noticed that my bow trim for the motor doesn't work at all.   Up or down.    Also notice that the running light switch is not functional, although it lights up when I turn the running lights on at the console.  Related or not?  It doesn't seem likely. Trim works at the throttle and the turn signal levers and the engine Where does the wiring go from the bow switch?   Straight to the engine, of through the drivers console? I had the trim and jackplate turn signal levers swapped left to right not long ago by the local shop.   I always say, the first rule in trouble shooting is to start looking where you last had your fingers. Is there a connector, or am I looking for bare wires? If it doesn't go through the console, where does it connect with the other trim wires?   Thanks
Home Forums Bass Cat Boats Bow panel Motor tilt not working
