That won’t complete the job. You MUST do the following before opening any bleeder valve.
1. Turn wheel to right until motor stops turning. Then open bleeder on right side of cylinder, prevent the motor from moving, and turn the wheel in the opposite direction until there are no bubbles visible. Close bleeder
2. Turn wheel to left until motor stops turning. Then open bleeder on the left side of cylinder, prevent the motor from moving, and turn the wheel in the opposite direction until there are no bubbles visible. Close bleeder.
To prevent the motor from moving while you turn the wheel with the bleeder open, you can (a) have a helper hold the back of the motor (helper needs to be pretty strong); (b) wrap a piece of leather around the steering ram shaft and clamp with vice grips. Critical to protect the shaft from scratches and nicks; (c) use a block of wood that fits between the steering cylinder and the bracket on the end of the steering pushrod. I use (b) myself.
You have to do this as otherwise, with the piston (internal to the cylinder) somewhere in the middle, there is room inside the cylinder to hold air bubbles. If you turn the wheel as far as it will go, you force that piston all the way to the end of its travel. That constricts the space on that side so that fluid coming in pushes any trapped bubbles of air out the bleeder port.
This is explained in the sea star / uflex cylinder bleeding instructions you can find from either supplier online… That way you will end up with rock-solid steering with no sponginess.
It is even better if you disconnect the cylinder from the tiller arm on the motor to let the cylinder go to its max travel position, otherwise you can still have a very small bit of space between the piston and the seal on that end that can trap a little air. Disconnecting the cylinder will let the piston move all the way until it contacts the seal/gland on that end to perfectly eliminate any possible air.
