Changing sonars have some questions
Im swapping out my Lowrance x51 in the bow and console and replacing with them Hummingbirds.#1 when I popped the transducer in the bilge area there is A LOT of epoxy still there ( no epoxy on the transducer at all ). The old transducer was mounted to get starboard side of center. Can I put my new one in the center or to the port side of center so I dont have to fool with scrapping the old epoxy?#2 Can I just clip the end off my Lowrance power cable at the bow since it was only 2 wires and splice in the new HB power cable since it is only 2 wires or do I have to run it across and patch it in behind the trolling motor connection, If I have to run it across what wires do I tie it into.#3 Is it best to just abandon the old transducer cable and clip the cable as close as I can on both ends?Thanks
Home Forums Bass Cat Boats Changing sonars have some questions
