2018 Lynx. All compartment lights stopped working. Removed ground wire from terminal block on transom and lights worked. This is first ground wire from left side of block on bottom. Appears to run toward front of boat. Lights work when this wire is removed from block but do not flash and automatically shut off as before. Lights stay on until lid is closed. Touch pad or connection at pad? I’ve seen this mentioned in relation to light alarm issues. Thanks for any advice.
