Does the bow seems to be digging in that sloppy water? If so, drop the engine. Don’t be shy to try 1/8”-1/4” below flush on the plate for those type of conditions, and that’s with any prop you like. Prop likes vary from person to person. Fury is usually the fastest on top end from my experience. Tempest lifts good and runs soft. Bravo should be an easy driving experience unless the motor is jacked up too high. I’ve ran those 3 props on the Puma and now Sabre I have. For me in the sloppy conditions, both boats ran/run better with all 3 props lower on the plate than most people’s jackplate settings I’ve seen. I always run extra light in gear too. From my experience, Cats don’t like the motor jacked up. They lift just fine with the motor lower than any other brand boats I’ve driven. Run the sloppy to rough water great as long as I don’t jack the motor up. Everyone has their opinions though.
