Dash panel issue
I have a 201& Eyra. When i try to run 2 pumps at the same time or lights on and run a pump everything will shut off after several seconds and seems to reset. I can only run 1 thing at a time if that makes sense. Not sure if there is some type of breaker or reset switch that is bad or needs upgrading to one that will carry a few more amps. I should be able to run the running lights and livewells at the same time. Thanks!
Home Forums Bass Cat Boats Dash panel issue
