Electronic/Ultrex/360 Upgrade
Hummm....Im up grading the electronics on the bow of my 2012 Cougar - Helix 10, Ultrex I-Pilot Link (80) and the 360 for the Ultrex.Since I installed the Helix 10 it shuts down when I start the big motor and it will also shut off on its own (wiring? Not enough battery?). Im using Optima 31M Blue Top currently. Im considering installing a Odyssey PC2250 to run the electronics and starting. and a PS3 Pro Series 3 bank charger for the Odyssey.Am I OK with the set up I have? Or is the Odyssey/PS3 the way to go?Ps - Ive been told the the issue of the Helix 10 shutting down when I start the motor is that it needs to be wired direct to the battery instead of to the power cable at the bow. As far as it just shutting down on its own ????Do I need a stand alone battery for the electronics?
Home Forums Bass Cat Boats Electronic/Ultrex/360 Upgrade
