Few questions – 2013 Puma FTD 250 Pro XS
Been having a blast putting in time with my "new to me" toy. My last boat was a 2005 Puma with 250 Verado so this is a bit of a different experience. The boat has 4 batteries, one power pole and came with a 25P fury. The jack plate was set about 1/2 inch above flush. The hole shot was great, excellent mid range acceleration, but I was seeing about 68 mph at 5500 rpm, plus significant left torque. Im sure there was more speed to be had, but it was a handful to say the least. I was running about 1/3 to 1/2 trim.So thanks to Ivan, I lowered the plate to flush. I also borrowed a friends 26P Fury who runs the same setup except his boat is a 2011. He runs 75 mph tournament loaded all day.I made some solo runs and found hole shot great and much easier to drive. I was seeing 72 mph at around 5600-5700 rpm. It was a handful at this speed and Im sure seat time comes into play. I was running about 1/2 to 1/3 trim.I fished a tournament last weekend with my dad, and Im not sure I could have run it to 70 if I wanted to although conditions didnt really allow for that type of run. Im not a guy who wants to run 80, just want the boat to perform to its abilities. Ill be trying the 25 fury once it comes back from being B & Bd.Any advice on setup is welcome and what should I realistically expect? I should also mention that the linkage had to be adjusted due to a fast idle when shifting into neutral...not sure if this has anything to do with it.Next...while fishing the tournament, my dad noticed some water while looking through the floor drain and we quickly noticed water coming out the top of the live wells with the aerator running...lol. Im guessing the overflow is plugged?? Turned on the bilge, pumped out the water and had zero issues rest of the day while making sure not to overfill the live well.Second last...when I took the prop off to return to my buddy the nut was snug, but not tight as when I put it on. Washers were put on thickest, thinnest, then medium thickness. Has anyone else experienced this before?? Lastly...I have a vent scoop on the starboard side but no intake scoop on the port side. Where does the air get into the bilge area??All very minor things and figured Id ask here where I know Ill get an accurate answer.I absolutely love this boat and dread the thought of ice on our lake!!Thanks in advance, Shane
Home Forums Bass Cat Boats Few questions – 2013 Puma FTD 250 Pro XS
