2017 Mercury Opti Max 150
So….I got all of the old gas out of the tank. I replaced the fuel/water seperator filter, put in 20 gallons of fresh fuel and added a bottle of heat for anything that may have been missed. I did have to tighten the filter at the ramp a little more after I tried priming the bulb because it was leaking a little air when I pumped the bulb to firm. Took it to the river and still will not start….
Back at the house I depressed the 2 Schrader Valves for any extra air or water that may be there. (Bottom Valve released air pressure top valve released fuel with good pressure. I drained the VST. (Small amount of fuel cam out and even tiltied the motor forward. The bulb holds firm when primed.
When I intially started the motor and it ran after a few cranks when it quit an alarm was sounding as it quit for the last time before all of this started.
Batteries are hot. The filter did not come with a new sensor. Does it also have to be replaced?
I am at a loss…….
