Home › Forums › Bass Cat Boats › Fuel line
Yes, The 3/8 line will work just fine.Chris CoupelPaulina, La.Chris CoupelPaulina, La.
Just an improvement!
Ok, thanks for the help guys. Chris
It is going to be time, and those fuel lines on the engine are the concern as it appears you have a Mercury. The boat lines are good, though from the tank or valve to the engine are not. BCB
what kind of hise
Marine Grade A1 in the proper ID.
You can get the Mercury kit, or the Attwood kit at WMT. They are the same now we believe.
Thanks for the quick response bcb but every where I look you have to pick a size choices are 1/4,5/16or 3/8
Most are 3/8. The smaller is used for the small tiller steer motors mainly.
The grey line is 5/16 and 3/8 is fine.
Thanks guys appreciate the help I was thinking 3/8 but its always nice to have somebody in agreement!!!
Existing lines are 5/16 and more than plenty.
=15pxhttp://www.bbcboards.net/showthread.php?t=22490
Thanks I am going to have the primer bulb and the grey line replaced.
From memory we think anything before 2012 needs the lines replaced.
