There are four bass model fuel tank variations.
1. Obviously one is the main single fuel tank of 33 gallons usable. Some of those models also have a light indicator to switch the gauge in dash, which does not function. As there is only one tank.
2. The Cougar FTD has two (2) rear fuel tanks of 26 gallons per side (52) and these function on the valve, which is the right left valve for fuel flow, located in the splash well. That does not change the gauge, which is changed on the A-Ten touch pad noted by that indicator LED in dash. Smart Craft gagues are notoriously slow to move as they avarage to prevent bounce in rough water.
3. Pantera II and Pantera Classic series with Kicker tanks of 10 gallons added to the standard 33 gallon fuel tanks. These have the A-Ten touch pad switch to switch the gauge only. They also have the dial vavle in the splash well which switches from the main (left) 33 gallon tank, to the kicker (right) fuel option of 10 gallons.
4. Jaguar, Puma and Pantera IV (Option 2 x 10 gallon), have the main 33 gallon fuel tank and the twin (2) 10 gallon kicker tanks. They have the switch for the gauge at the dash assembly. They also have the valve in the splash well for switching the fuel tanks. The valve switches from the main (left) 33 gallon tank to the twin (2) 10 gallon kicker tanks (right) which total 20 gallons.
These two rear tanks must be filled independently if you intend on using them soon after filling. They will siphon between tanks, though not in a rapid fashion for iimmediate use. They are t’eed together under the valve and the right pulls from both tanks simultaneously.
They will siphon to equal levels, if one side is added to for a pop of a couple of gallons added. Though you can not top off from one side only for immedaite use.
We hope this clears up the usage on the fuel tanks!
Never hesitate to ask your questions here, that is what this board is for!
BCB
