Fury 3 vs 4 blade
I know that a lot of you have tested this prop and compared them side by side on your boat. What I am interested in is the difference you have seen in RPM for changes from 3 to 4 blade. With limited experience on other Merc props switching from a 3 to a 4 blade same pitch the RPM went slightly down with the 4 blade. But how much on a FURY? Also a change of pitch on any same prop would typically be around 200 RPM. What have you seen?
Home Forums Bass Cat Boats Fury 3 vs 4 blade
