Help! Can not Disconnect Alarm-Screeching!
I have a 2008 Pantera Classic that I keep in my warehouse. A worker went to retrieve a ladder and called to tell me my alarm on my boat was going off. I went to the warehouse, Disconnected my battery charger and checked all the switches to make sure they were off. After some time I found the vision control panel on the right side of the console was not powered. Everything else seems to be working, batteries fully charged. I had replaced the vision panel before. (Has the horn, bait well, bilge pump and light switches on a Plastic switch stick-on round plate.) I figured the panel was bad again, and ordered another from basscat. I also found that my bilge pump and the pump by it were running. I figured that the vision panel was shorted, so I removed it from its round plate and unplugged it. The alarm still was running including the pumps. I was able to unplugg the pumps to turn them off, but no telling how long they had been running, but I would guess several days if not more. A friend got under the Console and unplugged everything around the screeching alarm he could find but it could not be turned off! I did not feel like disconnecting the battery, so it is still screeching. My boat security system was never turned on. Im hoping that theres some connection between the vision panel and the alarm that would be causing this.There is no wiring diagram. I ordered three Pump inserts because I think running dry would have ruined the impellers? Basscat parts and a mechanic had no workable suggestions.Have any other owners experienced condition? Any help would be greatly appreciated!Thanks,Skipjack68Palatka Florida
Home Forums Bass Cat Boats Help! Can not Disconnect Alarm-Screeching!
