Help explain random warning beep
03 FTD w/ 225 opti & smartcraft. This year since the OI I have been experiencing a loud warning beep coming from what I believe to be under the dash. It has only sounded while at idle, stays on for 1-2 seconds and goes away. This usually only happens once per trip. Engine temp has been anywhere from 80 to 130 degrees when sounding occurs so not overtemped. No alarms are displayed on the smartcraft and water pressure is normal. On the last trip out, the trim numbers have shifted up approximately 1.6. The motor typically was full down a split second after reaching zero and hit the trailer portion around 5.4. Now the full down is 1.6-1.8 and trailer portion begins at around 6.8. I dont know if the two issues are related and havent checked to see if the trim sensor has come loose. Any ideas? Not many trustworthy service places around so prefer to do any work myself. Thanks!
Home Forums Bass Cat Boats Help explain random warning beep
