I have a 2004 pantera iv,I took the original backup light off trailer and replaced it with 2 of the new style led lights.i soldered both black wires to the plug that was on the original light,and put ring terminals on the white wires and put them on the mounting bolts like the original.the lights dont work-any help would be appreciated.thank you!
In reference to the above comment: your old, incandescent bulbs are not polarity sensitive. Current will flow through them in either direction. The LEDs are polarity sensitive; wired in reverse polarity they will not function. Hope this helps.
