Its not hard. I did mine with the help of my wife. Need someone to hold it while drilling holes for mounting. I also set mine in place and held it level then measure from bottom of console to floor then cut a 2×4 to set it on to help hold steady. Will also need a 4 inch hole saw to cut access hole in side for bolts. Go SLOW as to not chip fiberglass ( cover with tape ). I put a piece of thin rubber between the to contact areas to keep from squeaking. I then made some flathead screws to fill holes when I take console out. Painted them to match. Only cost involved was price of console.Any questions give me a call. 937-475-3763. Mike
